switching from magnetos to electronic ignition?
bogger
Post by bogger »
Hi,
First post, new to this scene but sliding for 15 years. :D Need experienced advice for something that i never broke before -
I have a lycoming straight valve and had a magneto race bearing go and wallow out where it sits in the block - someone told me they could weld a new seat but have to breakdown the engine or go with a new engine. Now i dont have that kind of cash for a new engine and i don't knowhat kind of life i can get out of a weld. I'm sure it can be good. BUT someone also said an cheaper option is to switch to electronic ignition.
So, my questions are - what are the pros, cons and typical issues with doing this? :dontknow:
Thanks.
bogger
GMAC 76
Re: switching from magnetos to electronic ignition?
Post by GMAC 76 »
IMO.....when this kind of thing happens.....sell your mags and wires put a pacemaker ignition on it and never look back
SuprchgedPalmBeach
Post by SuprchgedPalmBeach »
Pacemaker is the way to go..just be sure and use the right tach for the pacemaker ignition.
diamondback0320
Post by diamondback0320 »
Right tach? Sorry not trying to hijack but watta mean by that..I have pacemaker and using the cable tach
SuprchgedPalmBeach
I use an electronic tach ran from the pacemaker box. So you see what the ignition sees, preference maybe?
diamondback0320
Yeah I've noticed that my tach is off compared to the pacemaker panel by best I can tell sitting on side of the boat strapped down on the trailer it's 100rpm higher than the mechanical tach if not more.. I'm guessing cause it's reading right at the flywheel
boatair
Site Supporter - VII
Post by boatair »
GMAC 76 wrote:IMO.....when this kind of thing happens.....sell your mags and wires put a pacemaker ignition on it and never look back
x2, I had the same thing happen but could still get the bearing to work. I have a pacemaker now and love it. It appears to have better throttle response and cranks instantly. I will never go back.
