DELRIN ROD
DELRIN ROD
Anyone know where I can buy 3 inch Delrin rod near Okeechobee, Fl
- Southern Airboat Member
Re: DELRIN ROD
Just bought some off EBAY.
Re: DELRIN ROD
Did you try McmasterCarr
Re: DELRIN ROD
Acetal is the material name Delrin is acetal made by DuPont
https://www.mcmaster.com/acetal/wear-re ... ngth~5ft-/
Re: DELRIN ROD
No, but I will check, Thanks.
Re: DELRIN ROD
didn't try McmasterCarr but will check with them if someone can give me an Idea as to where they are for I have never heard of them. thanks
Re: DELRIN ROD
Oh, And I had already found it on ebay and amazon but hoped to find it in the area if it wasn't too much higher than ebay. thanks again
Re: DELRIN ROD
Thanks, Guys
- kwanjangnihm
- Site Supporter - IV
Re: DELRIN ROD
OK I will ask - what are you using the rods for??
Re: DELRIN ROD
I'm using it to make bushings for a lawn mower, and machining a couple Idler pulley's for the drive pumps which have a bearing pressed into each of them.
