RPM's
MVICKERS
RPM's
Post by MVICKERS »
What should RPM should a new Levitator 6.0 run at. Mine is maxed out at 5200.
unforgiven11B
Re: RPM's
Post by unforgiven11B »
Per the owners manual that’s the preferred WOT maximum RPM. The optimal RPM range at WOT is 4800- 5600, 5200 being preferred by PCM/Levitator. Without a prop it’s max rpm is governed @6000.
MVICKERS
Re: RPM's
Post by MVICKERS »
Thanks very much ! Appreciate it !
