wood prop fire wood or can it be fixed.
josh_2562
Postby josh_2562 » Thu Dec 13, 2007 6:31 pm
can this be used again the pic makes it look really bad
Whitebear
Postby Whitebear » Thu Dec 13, 2007 6:52 pm
Josh
You should copy the image into your gallery here on SA then post it just like you did from there and it will show up here.
Scotty
josh_2562
Postby josh_2562 » Thu Dec 13, 2007 7:41 pm
the pic makes it look worse then it is
D-BREWSTER
Postby D-BREWSTER » Thu Dec 13, 2007 7:43 pm
GARBAGE!!
UNITED SPORTSMEN FOR TRADITIONAL HERITAGE
http://usfth.tripod.com/
CHECK US OUT ON FACEBOOK
http://www.facebook.com/usfth?ref=stream
Lastflcracker@centurylink.net
member of the USFTH ,K.R.V.S.A.,
Outlaw Airboat and Buggy board http://www.usfth.com
Geneva0550
Postby Geneva0550 » Thu Dec 13, 2007 7:46 pm
It would be ok to use that prop.....for firewood! :D
What do you mean the waters low and it's too dry?...You got an airboat!...ACT LIKE IT!!!!
p2
Postby p2 » Thu Dec 13, 2007 7:51 pm
Trash
josh_2562
Postby josh_2562 » Thu Dec 13, 2007 7:57 pm
10-4 I thought I read some where that they could be fixed. Thanks josh
Buck Thruster
Postby Buck Thruster » Thu Dec 13, 2007 7:58 pm
Make a clock out of it.......
Ride with pride. It's not illegal to be an airboater.
K-mac
Postby K-mac » Thu Dec 13, 2007 8:23 pm
Ya might could cut it down and put it on somthing smaller.
but if it were repairable, it would more than likely cost
more than a new one. Those props aint to expensive.
If the south would'a won we'da had it made!
cont520
Re: wood prop fire wood or can it be fixed.
Postby cont520 » Thu Dec 13, 2007 8:32 pm
josh_2562 wrote:Image
Brother it aint the pic that makes the prop look bad its that big piece of wood missing
Robert Mccormick
Plant City Florida, Toxic calls Pro staff and proud member of usfth
Ultimate Shot Productions prostaffer
josh_2562
Postby josh_2562 » Thu Dec 13, 2007 8:58 pm
yeah I know it just that I got to wait 2 weeks to get a new one from arrow props and I WANT TO TAKE THE MINI FOR SOME MORE RIDES :D
mudkat
Postby mudkat » Fri Dec 14, 2007 1:35 pm
If I were you I'd get a composite prop and be done with it,I haven't had very good luck with wood props,and the composites really seam to push better.
whitegator
Postby whitegator » Fri Dec 14, 2007 5:47 pm
fire wood!
Seminole Wind
Postby Seminole Wind » Fri Dec 14, 2007 5:53 pm
Give it to Raizincane,he'll use it.
THROW ALL THE RAT BASTARDS OUT.....RE-ELECT NO ONE!!!
F.T.M.F.
Be safe and keep yer knees in da breeze;
Vinny
http://community.webshots.com/user/hdbuckwheat
http://www.highlifter.com
http://www.svtperformance.com
Users browsing this forum: No registered users and 9 guests
