A little trick for you DD guy's in airboating magazine
Waterthunder
Postby Waterthunder » Thu Feb 14, 2013 2:58 pm
I have walked some people thru this when they building their own DD car motors. This is a cheap and easy band aid that improves bearing life. This works on motors that have a rear thrust bearing such as a SBC or BBC. What this does is guide pressurized oil from the bearing and directs it to the thrust face surface of the thrust bearing it's simple and effective. You take both bearing shells and with a small jewelers file you file a 45 degree chamfer on both sides of the parting line on both bearings when you hold them together you can see how oil is now flowing to the thrust face. Here is a pic of what you need to do. I have a dozen or so people with DD's that were wiping out bearings quick and after they changed bearings and did this their problems went away.
THE PROOF IS IN THE PROP!
http://waterthunder.com/
321-508-5316
Waterthunder
Re: A little trick for you DD guy's in airboating magazine
Postby Waterthunder » Thu Feb 14, 2013 3:11 pm
Here is a pic of what you need to do to help improve bearing life on a DD.
321-508-5316
JAMES
Postby JAMES » Thu Feb 14, 2013 6:06 pm
Waterthunder wrote:I have walked some people thru this when they building their own DD car motors. This is a cheap and easy band aid that improves bearing life. This works on motors that have a rear thrust bearing such as a SBC or BBC. What this does is guide pressurized oil from the bearing and directs it to the thrust face surface of the thrust bearing it's simple and effective. You take both bearing shells and with a small jewelers file you file a 45 degree chamfer on both sides of the parting line on both bearings when you hold them together you can see how oil is now flowing to the thrust face. Here is a pic of what you need to do. I have a dozen or so people with DD's that were wiping out bearings quick and after they changed bearings and did this their problems went away.
THATS GREAT BUT U SAID BAND AID HOW LONG DOES IT LAST AND IF JUST A LIL LONGER THEN NORMAL HOW CAN U FIX THE PROBLEM OTHER THEN GOING GEARBOX OR AC/GPU TO LAST A NORMAL MOTORS LIFE !?
jimmy
Postby jimmy » Thu Feb 14, 2013 6:10 pm
what's "NORMAL" in an airboat??????????
HVGator
Postby HVGator » Thu Feb 14, 2013 6:34 pm
Should this filing be done just to the thrust bearing or all bearings?
13 ft Diamondback, GSO-480, 4 blade Q, gas tank too small, not enough cash to fill it.
rocketrob
Postby rocketrob » Thu Feb 14, 2013 6:48 pm
Dave ; maybe you have tried this , but what about filing that same notch in the upper bearing only directly in line with the oil hole in the bearing ? Could this supply an even better flow to the thrust surface ? Of course the sizing of the groove would be paramount as to not bleed too much oil psi off the rear main and of course the groove will only supply oil to the required thrust surface ?
Rob
rocketrob
Postby rocketrob » Thu Feb 14, 2013 6:54 pm
Dave ; Not trying to steal your Thunder LOL , but my mind is always working on these kind of problems .
Rob
JAMES
Postby JAMES » Thu Feb 14, 2013 7:27 pm
jimmy wrote:what's "NORMAL" in an airboat??????????
IF THATS ADDRESSED TO ME ID SAY SINCE WATERTHUDERS MOTORS ONLY COME WITH A 1YR WARRANTY ID SAY 1 YR :D
NO MAN ID SAY EVERY FEW YRS B4 THE EVERYDAY SBC NEED TO BE GONE THROUGH DD WISE
jimmy
Postby jimmy » Thu Feb 14, 2013 7:44 pm
what i meant james, is that , is there such a thing as normal on an airboat? i have seen some worn out junk with 100,000 miles pulled out of a pos car and ran on a boat for years, and then some HIGH DOLLER brand new engines, not able to make it to the end of the canal
before hearing tic tic tic,,,BOOM
what is normal?
DAVE, when ya file yer edge .do ya tend to file towards the side of the bearing that will see the thrust?
crowhater
Postby crowhater » Thu Feb 14, 2013 9:14 pm
Hey Dave thanks for taking the time to pass on a little knowledge.
Wild Bill
Postby Wild Bill » Thu Feb 14, 2013 10:11 pm
That's the old Waterthunder that helped out the the little guy back when I started out. Truly appreciated the wisdom and PM's :cheers:
So yeah just the thrust say center of the bearing to the rear.
yobee
Postby yobee » Fri Feb 15, 2013 4:48 am
This is very helpful to me.
Jake.R
Postby Jake.R » Fri Feb 15, 2013 6:34 am
crowhater wrote:Hey Dave thanks for taking the time to pass on a little knowledge.
X2 thanks!
14x8 Alumitec SS Rigging
383 Stroker CH-4 2.67
81" 3 Blade S
dan-o
Postby dan-o » Fri Feb 15, 2013 7:50 am
yobee wrote:This is very helpful to me.
:laughing3: :laughing3: :laughing3: :laughing3: What a d!ck. lol.
"Disneyworld and air conditioning is gonna ruin Florida."
-My Grandmother-
CarMotorBarge
Postby CarMotorBarge » Fri Feb 15, 2013 10:12 am
You didn't know Yobee was putting a direct drive EcoTec on his boat. Give him a call. He is trying to get the great fuel mileage of an EcoTec and the great fuel mileage of a DD all in one package. Told me he was planning to get 20 MPG.
Waterthunder
Postby Waterthunder » Fri Feb 15, 2013 10:19 am
I have helped several people do this and some have 3, 4, 5 years on their motors. I tore one apart one because the owner wanted me do hotrod his motor and the thrust showed zero signs of wear he had .012 crank end play on a 400 SBC after around two years of running.
321-508-5316
yobee
Postby yobee » Fri Feb 15, 2013 11:24 am
That is an offensive post. Name calling is not appreciated.
:thumbleft:
Quick Draw
Postby Quick Draw » Fri Feb 15, 2013 11:31 am
Lmao :lol: :lol:
:thumbleft:
Waggin
Postby Waggin » Thu Feb 21, 2013 10:17 pm
cool tip, would also work in a car with manual transmission, Thank's for sharing
2012 Bud Built Barracuda 11', Dual Stick Controls, ZZ4 aluminum head crate motor and two blade water walker on steel rigging 4412 2 bbl
Olf Art
Postby Olf Art » Fri Feb 22, 2013 2:24 am
Waterthunder wrote:I have helped several people do this and some have 3, 4, 5 years on their motors. I tore one apart one because the owner wanted me do hotrod his motor and the thrust showed zero signs of wear he had .012 crank end play on a 400 SBC after around two years of running.
Cool tip, Dave ...... thanks for passing it along! It's really pretty amazing that the thrust bearings hold up as well as they do when
you think about the amount of pressure that's on them when the engine is turning a prop.
Not only do you have radial loads from the weight of the prop (never mind what that bearing is going through if your prop isn't balanced!) but enough thrust load to shove you and your entire boat up on plane and then keep you there. Wow.
Is there any one brand of bearing that seems to hold up better than the rest? What about brand/type of engine oil?
