I like to start at max pitch so you know where you are. Hopefully it is choked down. Then take out some pitch, see how many RPM you gain. From there you should be able to zero in on target with a 3rd and final adjustment.
If you start too low on pitch, all you learn is you had to let off before WOT with not much else direction other than needs more pitch.
