any difference?
flcracker91
Active member
Is there any difference between a prop used for direct drive to a gearbox? Some 1 told me i had to b careful buying a prop to make sure i get the wright prop for my 12 ft cotton mouth that is going to hav a chevy 4.3 thats going to b dd is this true thank for the help :thumbleft:
YES DD LEFT HAND AND BELT BOX LEFTHAND --- GEAR BOX RIGHT HAND
IF IT CARBONFIBER THE HUBS WILL BE THE SAME FOR R-AND L THE BLADES ARE DIFFERNT
AND IF YOUR BUYING A WOOD PROP IF U ARE U CANT CONFUSE THEM FOR YOUR 4.3 WHY? THE 4.3 WILL TAKE A MUCH SMALLER LENTH AND PITCHED PROP THEN ANY GEARBOX
EXAMPLE DD 4.3 WOULD BE AROUND 68/30 OR SO A RIGHT HAND WILL BE AROUND 76+X 48+ FROM MY EXPERENCE LEFT HAND BELT BOX IVE SEEN THEM 72" AND UP THE AIRCRAFT GEARBOX WHICH IS WHAT BILL ROBERTS BUILDS FOR CARMOTORS ARE LEFT HAND AS WELL
flcracker91 said:
yes im planing on using a wood prop. so i need a left hand prop that is 68/30 correct?
WELL NOT EXACTLEY 68/30 IT CAN VARY ID KEEP IT AROUND 66-68 X 30-32 STICK PROP
DO U NO THE DIFFERENCE IN STICK AND PADDLE ??? STICK PROP IS NARROW THE PAD PROP IS WIDE
GOOD LUCK MAN
AND WHEN BUY A WOOD PROP MAKE SURE ITS IN GOOD COND U DONT WANT A DENTED UP EDGE PROP OR SIGNS OF SPLITTING OR ALOT OF WEAR THEIR ARE DIFFERENT BOLT HOLES ON SOME OF THE WOOD HUBS AS WELL ....TAKE YOUR ADAPTER WITH U WHEN U GO BUY IT .........
