i just checked compression on my 220, starting at the prop on the left side they are 150,162,115 and on the right 145,125,145. also on the left bank i have black smut and when you crank it you can hear it popping a little when its cold. which of these numbers are normal and how close should they be? seems to run and idle great. i would like some advice from you guys on what i should do.
