I have custom oil pans in stock take's off 15 pounds of weight.
i can send pictures if needed. they are gpu oil pans. cost $ 300.00 outright/175.00 on exchange.
a 470 aircraft case is different like speed already said and the oil pan will not work. you can make a custom complete oil pan or just the bottom half the oil pan, I have also taken a e series oil pan and used it with a e-series accessory cover or modified the pan for a stock Gpu cover . I guess mine must have been heavier when I weighed one it was 26 pounds for the bottom section alone
friend of mine has an oil pan on his 220 that westside made.very nice.used the top of the stock one and built a new bottom.doesn't leak.i'm told if you don't use the stock flange its a bugger to keep'm from leaking.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
