Torque Specs and Clearances
Here you will find all of the recommended clearances and torque specs needed for building most Cadillac 472, 500, 425, and 368 engines. This is not an exhaustive list of every possible combination, just the numbers for the most common stuff. When in doubt, especially if using trick aftermarket parts, use the clearances and torque specs provided with the parts.
Torque Specs
Stock Rods with Stock Bolts: 40 Ft-Lbs
Stock Rods with ARP Bolts: 50 Ft-Lbs (with ARP thread lube)
Aftermarket Rods with ARP Cap Screws: 65 Ft-Lbs (with ARP thread lube)
Aftermarket Rods with ARP 2000 Cap Screws: 75 Ft-Lbs (with ARP thread lube)
Main Bolts: 90 Ft-Lbs
ARP Main Studs (with ARP thread lube): Head Bolts: 115 Ft-Lbs
ARP Head Studs (with ARP thread lube): Intake: 30 Ft-Lbs
Exhaust: 35 Ft-Lbs
Cam Bolts: 25 Ft-Lbs
Rockers: 55 Ft-Lbs
Valve Covers: 10 Ft-Lbs
Flex Plate: 50 Ft-Lbs
