swamp runner said:ace hardware , as far as i know it only comes in 4' and 5' rolls . you should only have 1 seem up the center top half of the gaurd and a strip around the hoops .
yobee said:You can buy 1/8" round stock and hand lay it piece by piece. Looks awesome and is a lot stiffer at the end. You can buy it in regular steel or stainless from most steel suppliers. If you can only find it in stainless you can still weld it as if it were normal mild steel, but it will need to be covered (ie primer and paint like the rest of the emt or steel) My friend "Apache220" just did his cage for like $30 in materials if Im not mistaken and it looks freaking sweeeettttt.
