Looks like another item related to the oil pickup tube O-ring. Everything says replace the pickup O-ring whenever you can. Kind of a Duh, but I need to make sure I get the right one to get a good seal and not starve the new motor for oil.
It turns out there are 3 different designs for the pickup tube shape, with different O-ring dimensions required. It turns out I have 2 of them. The L92 Truck oil pickup tube has the tapered design and has the red O-ring on it. The LS3 oil pickup tube is the straight design with the Blue O-ring on it.
Here is the Melling seal reference table.
Both of the seals are damaged, so a new one is going on.
These pictures show the tapered L92 Truck pickup with the fatter O-ring.
The LS3 pickup tube that I will be using is straight, measuring at the same diameter as the wide end of the tapered truck tube. I need the skinnier, 1/8" cross section seal (Blue or Black).
| LS Oil Pickup Style | GM Seal Color | Melling Seal Color |
| Grooved | Red | Green |
| Tapered | Red | Green |
| Straight | Blue | Black |
