Thanks poobought. The boats looked very similar. I was just trying to understand why the weights were so different.
Thanks Bigun. I was trying to understand why you didn't try an 84 inch 4 blade R pitched at close to 2 on your new boat and turn the engine at 5400. I would expect more static thrust because of the additional prop length, but also more torque roll. Sounds like you were worried about torque roll.
So I have been thinking about all of this prop testing that is being done by the North Florida guys. This prop testing is very useful for static thrust. The problem is that this testing only shows how well your boat will do when breaking loose on the hill or moving at slow speeds. It doesn't show dynamic thrust while at a cruise or hauling butt.
Look at Anvil's boat. He has his prop over pitched so that he gets better fuel mileage. He is getting better fuel mileage because of lower engine RPMs, but I suspect that he is also getting better fule mileage because he has more dynamic thrust.
The Sensenich R blade is supposed to be the most efficient set on 2. However I think this is only true when the boat is not moving. As the MPHs that a boat is traveling at increases, an R blade set on 2 will become more inefficient. That is why the over pitching helps. It makes the prop more efficient at higher boat speeds. However you give up static thrust.
This is the entire idea behind the variable pitch prop that David Wine was talking about several months ago. When you are stuck, you can set the pitch at 2 and get the most efficiency. When you are traveling at 30 MPH, you can over pitch the prop and maintain the same efficiency.
So I am bringing this up to see if there are any ideas about how to test dynamic thrust. Without this data, you cannot get a complete picture of how well a prop combo performs. This goes for performance, fuel mileage, and sound.
Look at Biguns boat. Should he use a 4 blade 82 inch R pitched at 3? This gives him the flexibility to adjust static and dynamic thrust depending on where he sets the pitch. However what happens if he uses a 4 blade 84 inch R with a 2.68 gearbox? He could set the engine WOT at 5400 and make more static thrust then the 82 inch R. He could also pitch the 84 inch R and bring down the engine RPMs to get better fuel mileage and increase dynamic thrust. Will this provide better fuel mileage and more dynamic thrust than his current setup (82 pitched at 3)? I don't know, but it would be nice to get this type of data.
Please do not think that I am saying that the current thrust testing is being poorly done. I personally think that it is being well done and has caused lots of useful conversation about something very important to the airboat industry and how it is perceived by the general public. :salute: I am just trying to help out from over 200 miles away.
