If you wasn't gettin' so damn old you wouldn't have to keep fixin' stuff.anvil said:Soon as i get my boat back together I plan to pull a little pitch out of the prop and get into that sweet spot as well. Should be fun. My thanks to all that have added to this project. like my by line says the company of men who seek the truth are much prefered to those that think they have it. My boats are works in progress. One change sparks three more. A guy told me at a knife show years ago that he owned Abraham Lincolns original axe. But it had three new heads and fourteen new handles since it was in his hands. I am starting to feel the same way about my boats.
Waterthunder said:Here is some good info the Waterthunder motor was brought to me because the new owner wanted us to fix an ignition problem with the MSD. So we took the motor and installed a 2.38 and ran it on our thrust tester. We set the RPM's to exactly the same they had it turning 5050RPMs on the trailer test. And made a few pulls then we set the pitch to turn 5,500RPM's. The only other change we made was for some reason someone removed the #5 chip and installed a number one chip in the MSD so we reinstalled the #5 chip. Here are the numbers going from 5050RPM's to 5500rpm's we picked up 286lbs of thrust can you imagine that 450RPM's picked up 286lbs of thrust. I can 5000RPM's is just below the sweet spot and the extra 500RPM's is where the motor and prop both start working.
So the next test we are installing a 2.68 and we will post the difference. I will tell the new owner how much more thrust he makes with the 2.68 over the 2.38 then the difference can be compared to the numbers they get with the 2.68 on the thrust trailer. I know it's going on a different boat so it will be interesting to see how changing the rigging will effect the forward thrust. I know when we raise a motor just an inch it changes the readings let alone how much thrust can be lost going downward instead of forward.
I had somebody say it's not much but they had to agree when the heard we bent a few trailers down and ruined them. Obviously a bunch of force was pushing down if you can bend a trailer.
PS just changing the chip dramatically improves the idle when you have more timing at idle the motors run smoother and tend to shake less.
PS PS The MSD problem was in the harness it looks like somebody didn't flip the cam sensor polarities when the MSD was installed.
HuntingBigun said:ALl good JMO data is data, the cool thing is if you could put the complete boat on the trailer and see what changes with the rigging, heck nobody gave cntry crap for posting about his testing![]()
Be cool to have both kind of testing
Question if you have a 2.68 turn 5400 rpm = 2014 prop rpm
then you have 2.5 turn 5000 rpm = 2000 rpm
I know mine is a blower but would that not be the case for me why my boat liked the 2.5 better than 2.6??
