fl cracker said:The 540 shows numbers at 950 with a 3 blade at #2. the 520 shows less thrust #'s at the same pitch but the props are set the same with the same RPM. I don't understand?
hogdoggin said:Are you guys going to try the Q prop on the 540 boat? Like to see the difference between the 2 props on the same boat. I have a 3 blade NGH on a 540 and by the seat of the pants I feel it has more over all push than my old 2 blade Q but I thought my Q had better low end push less RPM's to move on the ground. But the Q to me felt like once you got to a point say 2700rpms it just fell off where I feel that the NGH keeps on pushing. Thanks for all that you'll have put in to this!! :cheers:
Roxy7430 said:I have a correction to make:
I stated earlier that we verified the tach on every boat. We did put the digital timing light on every boat but.......the 520 wouldn't give us a reading for some reason. Therefore the RPM is unverified on that boat. Maybe the tach is off causing some of the confusion??
Sorry for the oversight.
jre1226 said:Roxy7430 said:I have a correction to make:
Thank you guys a lot for all the hard work, money, time and effort you guys have put into this. Would I be wrong in saying that the 520 results are not useful until we know whether or not that tach is accurate. My thinking is if he is reading 100 to 150 more than he is spinning (not uncommon) it may very well be like cntry said he is not putting out the same power as the 540. Or if his tach is accurate then we can assume it is somewhere in the airflow restriction. Please correct me if I'm wrong.
Rigging,cage design,and seating arrangement all play a part in the thrust numbers.fl cracker said:A prop set at the same length and pitch and spun to the same RPM should produce the same numbers across the board IMO no matter what motor it's on. Am I missing something ?
Tony480 said:Rigging,cage design,and seating arrangement all play a part in the thrust numbers.fl cracker said:A prop set at the same length and pitch and spun to the same RPM should produce the same numbers across the board IMO no matter what motor it's on. Am I missing something ?
hogdoggin said:Tony480 said:Rigging,cage design,and seating arrangement all play a part in the thrust numbers.fl cracker said:A prop set at the same length and pitch and spun to the same RPM should produce the same numbers across the board IMO no matter what motor it's on. Am I missing something ?
I agree with tony 100% thats why i was hoping they would test the Q on the 540 boat. I know every boat is going to produce different thrust numbers. I was just wanting to see the differents between the 2 props NGH and Q on the same boat just to get a idea which prop produced more thrust.
Big Casino said:Interesting test showing results from a Timing Adjustment
skinny99 said:Big Casino said:Interesting test showing results from a Timing Adjustment
Am I reading that chart wrong? Looks like you changed timing and pitch at the same time? If so then the timing is really a non-factor. Less pitch=More RPM's and in this case=less thrust. Or am I misreading it?
Changing two things at one time makes analysis really difficult to me.
